Home > Technical > FM Antenna Fault and no DAB reception
nplatts
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Zambezi Silver
Hi I have an early 2010 facelift that has a fault, it started out as getting no reception on the DAB intermittently but now the DAB just says no reception all the time, there is a FTC in the diagnostics of B1D5514 FM Antenna Fault, would this be related and if so is there a module that I can replace to fix? any help appreciated...
Post #521112 Thu Mar 16 2017 4:59pm
Orange RRS
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Make sure the connector hasn't come off the rear side glass, they just pop on. It uses a little signal booster up in the headlining I honestly can't remember which one is the DAB, but check the connector on the side glass first. Life's too short to drive boring cars !
2005 Supercharged First Edition
2013 Evoque
Post #521113 Thu Mar 16 2017 6:12pm
nplatts
Thanks, tried those popped them off and refit but no change, also done the reset process with the battery. Do
the FM modules do the DAB as well? Is it worth me swapping them with the dtc code complaining?
Post #521114 Thu Mar 16 2017 6:25pm
Orange RRS
Depending on the spec of the car there are a few modules in the headlining, I think the fm is on the rear screen as well as the sides. Dab and tv I think are on the sides. See how many connectors you have on the rear and side glass. I have a few amplifier modules at home, they are colour coded. Also worth checking the amplifiers are being powered up and have a good ground. Life's too short to drive boring cars !
2013 Evoque
Post #521129 Thu Mar 16 2017 10:28pm
nplatts
Thanks, there are three connectors, no TV on the car, ill have a look at the modules this weekend.
Post #521134 Fri Mar 17 2017 6:03am
Lsmcars
Hello
I have basically the same problem! Did you ever get to the bottom
Of it?????
Post #606019 Wed Oct 28 2020 12:47pm
