Home > In Car Electronics > USB Socket |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 200 |
Mine did the same when I connected both my iPod and USB stick. It took a few minutes for the stars to align then it indexed and I was up and running. Give it try again, 2018 Telsa MS
Sun Mar 12 2017 10:31am |
turbotim Member Since: 06 Feb 2017 Location: Kent Posts: 14 |
Thanks. I'm not near car at moment, but will try that later |
Sun Mar 12 2017 10:33am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4972 |
If it is a broken wire you can buy a new wiring harness link to replace it without replaceing compete harness, just a plug and play section.
Sun Mar 12 2017 9:00pm |
Drove to work this morning, a 20 minute drive, with USB selected, no luck.
Mon Mar 13 2017 6:07pm |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
What format is the USB? It needs to be FAT16/32. Also, I think it only reads MP3 files. |
Mon Mar 13 2017 6:17pm |
Thanks for the advice,
Mon Mar 13 2017 7:16pm |
I may have solved this! My USB (which happened to be 16 GB) only worked intermittently, and was slow to load when it did work. I looked for another USB to try, and first found an old 0.5 GB one. I uploaded three CDs to that (which filled it), and it worked instantly. I then put the same three CDs on a 2 GB USB and it was almost as quick to load. The 16 GB one is still intermittent, indeed wouldn't work at all last time I tried. I therefore conclude that in their incessant drive to go backwards, JLR have installed a USB port which won't accept large memory USBs, or USB 3, and that therefore you will have to scour your house for ten-year old USBs to suit the 'latest' RRS technology. I anticipate that in the same spirit of technological retreat, the next RRS will only have 2G rather than the very latest 3G it has now!
Tue Mar 14 2017 2:30pm |
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 |
I have this Thumb drive:
Tue Mar 14 2017 4:00pm |
You amaze me, as my 17MY car wouldn't read even a 16 GB USB reliably, whereas it works perfectly with smaller memory USBs. Is there something special about this Thumb Drive that makes it better? (Indeed, what is a Thumb Drive?) |
Tue Mar 14 2017 5:35pm |
I drove to work this morning and it started playing
Tue Mar 14 2017 5:43pm |
ah...MY17, apologies, maybe they have gone backward! |
Tue Mar 14 2017 5:52pm |
