Home > Faults & Fixes > Suspension fault yellow warning
Page 4 of 4 <1234
Gibson
No mate the rumbling seems to be there all the time now whatever the suspension does its getting rather loud see what the garage says tommorow
Sounds like a bad wheel bearing rumble but it passed an mot two days ago then again probably same garage that did the bloody service!! Evil or Very Mad
Post #518296 Sun Feb 19 2017 8:50pm
Gibson
Going in today for a check over guy on phone seems to think it may be the arc bar will update when I find out
Post #518445 Tue Feb 21 2017 7:08am
Gibson
well car came back from les potts I topped fluid up light has stayed off since rumbling noise ive managed to fix the bloody wheel nuts were finger tight should have been picked up on an inspection I would have thought inspection revealed front arc bar had been repaired rather than replaced
Post #518601 Wed Feb 22 2017 2:08pm
docian
United Kingdom 2008 Range Rover Sport TDV8 HSE Santorini Black
Thanks for update, did Les Potts say any remedial work was needed to the ARC bar? Did he explain the front suspension level by the ARC bar failure or just running too dry?? Shows what a car sales garage thinks constitutes a service! Worth getting an early service and check over by a Landy specialist IMHO
Post #518613 Wed Feb 22 2017 4:26pm
Page 4 of 4 <1234
