![]() | Home > Technical > RRS Swimming pool |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Trim and clips have been replaced, not really had any rain since so I'm still unsure if I've resolved the issue or not.
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, had this with mine and it was the dreaded A pillar clips and hole. I used duct tape to cover the bottom slot and also removed the foam block, Have you removed it ? |
The bottom trim clip (that you plug in after fitting the trim) is pretty Loose, I'll maybe see if I can pick up a new one. I've not removed the foam on the bottom, I presumed it was a baffle to stop whistling etc. |
Hi, it probably is a wind baffle thinking about it but iv'e not noticed any noise. It turns into a solid block with dust and whatever hence the water back filling up the a pillar in to the slotted hole during longer periods of rain |
