Home > Technical > RRS Swimming pool |
Trim and clips have been replaced, not really had any rain since so I'm still unsure if I've resolved the issue or not.
Fri Feb 10 2017 10:29am |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi, had this with mine and it was the dreaded A pillar clips and hole. I used duct tape to cover the bottom slot and also removed the foam block, Have you removed it ? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Fri Feb 10 2017 11:28am |
The bottom trim clip (that you plug in after fitting the trim) is pretty Loose, I'll maybe see if I can pick up a new one. I've not removed the foam on the bottom, I presumed it was a baffle to stop whistling etc. |
Fri Feb 10 2017 1:26pm |
Hi, it probably is a wind baffle thinking about it but iv'e not noticed any noise. It turns into a solid block with dust and whatever hence the water back filling up the a pillar in to the slotted hole during longer periods of rain 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Fri Feb 10 2017 5:53pm |
