Home > Faults & Fixes > Another suspension fault
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
for a few days now, as I've been driving along I get the 'bing' and on comes the amber susp light and 'suspension fault' is displayed. Car doesn't drop, if I use the height button it will raise and lower. Tonight I decided to sit in it and make the susp do its thing by sending it up and down and watching the monitor on the dash. The n/s/r wheel icon is jumping about all over the place, and the white lines that depict the sensor, go red for a second. If the susp is in extended mode (fully down) and I send it up, it goes up very slowly and says so on the facia. Then it said 'Vehicle will raise when the system has cooled down' Shocked
I know these are plagued with susp problems, but in peoples experience on here, will this sensor be causing my issue?
Thinks it's time I bought an IID or Icarsoft LR2 Rolling Eyes
Post #516584 Thu Feb 02 2017 8:09pm
Socast
Before replacing the sensor, check the wiring to it. You may get away with some electrical contact cleaner.
Post #516632 Fri Feb 03 2017 1:22pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Have you checked for any leaks on the compressor drying chamber. Just remove the plastic cover underneath think its 3 bolts from memory then a few sprays of strong soapy water onto the cap of the drying chamber, and any of the air lines if these a leak it will bubble up.
This is what happened to mine
[URL=]
[/URL]
Post #516640 Fri Feb 03 2017 3:11pm
gary3306
The connector was my first port of call and that was spotless, like new. I have some time over the weekend so will check for compressor leaks Dan. Just hoping I haven't got a sticky valve block. Bl66dy cars Rolling Eyes
Post #516672 Fri Feb 03 2017 8:12pm
