Home > Faults & Fixes > Another suspension fault |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 |
for a few days now, as I've been driving along I get the 'bing' and on comes the amber susp light and 'suspension fault' is displayed. Car doesn't drop, if I use the height button it will raise and lower. Tonight I decided to sit in it and make the susp do its thing by sending it up and down and watching the monitor on the dash. The n/s/r wheel icon is jumping about all over the place, and the white lines that depict the sensor, go red for a second. If the susp is in extended mode (fully down) and I send it up, it goes up very slowly and says so on the facia. Then it said 'Vehicle will raise when the system has cooled down'
Thu Feb 02 2017 8:09pm |
Before replacing the sensor, check the wiring to it. You may get away with some electrical contact cleaner. |
Fri Feb 03 2017 1:22pm |
The connector was my first port of call and that was spotless, like new. I have some time over the weekend so will check for compressor leaks Dan. Just hoping I haven't got a sticky valve block. Bl66dy cars |
Fri Feb 03 2017 8:12pm |
