Home > Maintenance & Modifications > eBay side steps
Smarttech
eBay side steps
Anyone had or know what the steps for sale on eBay are like ? I see genuine LR steps seem to be about £600 but I see the eBay ones start at about £118.
I had steps on my last RRS 10 years ago and found them pretty useless as a step but think they finish off the look of the car better than just having the door moulding sticking out.
Post #516508 Thu Feb 02 2017 6:54am
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
My experience is,they eBay steps are great value,fit perfectly but the aluminium does tarnish very quickly.I had genuine steps on my first sport and that aluminium tarnished as well but the metal did seem better quality.
The bay version just needs some wax applying to give it some protection. Thumbs Up
Post #516509 Thu Feb 02 2017 7:01am
Smarttech
I see for a little bit more you can buy them with sill protectors. Is it worth the extra or are these just traps for wet road dirt to sit in ?
Post #516512 Thu Feb 02 2017 7:42am
wings21660
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
I got mine of fleabay for my last rrs they were easy to fit but did discolour along the aluminium strip. If you do buy some make sure you strenghten the strips before you bolt them to the car they are well known for popping off when the rivets rust, I had to re-drill both sides it would have been easier off the car, hope this helps mate Thumbs Up
Post #516513 Thu Feb 02 2017 7:57am
Smarttech
Strengthen the strips ? What part are you n about when you say strips
Post #516514 Thu Feb 02 2017 8:07am
wings21660
There is an aluminium strip goes from top to bottom held on by rivets that rust, Ive just had a look on ebay the first set I come to shows them quite clearly
Post #516517 Thu Feb 02 2017 8:14am
PEACHY
Side steps can be purchased with either precut - none cut or no replacement sill protectors at all. You need to remove your current sill protectors as part of the step installation.
I would buy the precut sills - this is a lot easier IMO - only other advice - clean regular & seal as often as possib;e. Once they are tarnished they are a Censored to get back too pristine condition. Thumbs Up 16MY Estoril Blue SVR.............
Post #516520 Thu Feb 02 2017 8:28am
Tyrefitter
As Peachy say's,,def get the ones that's pre-cut.It took he half hour a side working on the floor with suspension raised.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #516521 Thu Feb 02 2017 8:39am
mrfixit
I got mine with pre-cut sills for about 120 delivered next day.Only other bit of advice I would offer is to get yourself an 8mm tap to run through the holes before you try and get the bolts in. Wink
Post #516571 Thu Feb 02 2017 6:27pm
d-9
Got a link to where you got them from?
Post #516591 Thu Feb 02 2017 9:15pm
mrfixit
That was the seller carvantruck2010
Post #516593 Thu Feb 02 2017 9:34pm
Smarttech
Cheers Peachy for the link, your a star. Will find some with the sills ready cut and get some ordered ready for when I can collect the car from the dealership next week.
Post #516601 Thu Feb 02 2017 10:27pm
d-9
Thanks mrfixit
Post #516604 Thu Feb 02 2017 10:50pm
Smarttech
Which eBay seller did you buy them from ?
Post #518447 Tue Feb 21 2017 7:51am
Smarttech
Cheers Bright blue Thumbs Up
Post #518477 Tue Feb 21 2017 1:21pm
