![]() | Home > General > RRS 2005 STEERING GONE STIFF - HELP REQUIRED |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
Try the steering column knuckle joint, they seize on older vehicles, I had mine replaced last year, they cost about £100 plus labour.
DavidHem Member Since: 07 Oct 2016 Location: Warwickshire Posts: 38 ![]() ![]() |
check for leaks where the in and out pipes are bolted to steering rack, you can see them by turning the steering wheel fully clockwise and look from the drivers side wheel, it is common for one or both of the seals to go leading to a slow leak, they are very very easy to change and cost less than £4.00 from a main dealer.
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
Issue found it is the UJ Joint.
My indie sourced one in an hour, delivered to his workshop, There must be one in Birmingham 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Not an item Land Rover stock however deliver within 24 hours.
Thats what I meant, an indie, a local specialist 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Problem solved steering perfect
