Home > Maintenance & Modifications > Wonky Pipes
dal74
England 2005 Range Rover Sport Supercharged HSE Java Black
Wonky Pipes
As the title says really.
I had a replacement cat back exhaust fitted to my 2005 4.2 sc today and upon getting home noticed the left tailpipe slightly facing downwards compared to the right. Now i have never really looked at the pipes before for levelness and was wondering if this is normal? I assume not and will take it back in the morning, also is this an easy adjustment does anyone know?
Oh it sounds lovely now and has a reallly nice v8 burble at low revs (like a big block yank)
Post #514689 Mon Jan 16 2017 4:19pm
Black Bess
They should be able to slacken a joint and twitch the pipe round a bit.
Post #514803 Tue Jan 17 2017 10:53am
Socast
Go straight back and get them to do the job properly.
I would also ask them why they gave it back to when it's obviously not fitted correctly.
Post #514819 Tue Jan 17 2017 12:49pm
dal74
Took it back straight away and had them adjust the pipes correctly, all is good now. I just asked as id never looked at the pipes before and didn't know if there was a slight difference in alignment. Embarassed Embarassed Embarassed
Post #514942 Wed Jan 18 2017 4:39pm
