Home > Faults & Fixes > rear lights
Throbby
rear lights
Hi,
RRS 2.7d 2006
my rear lights - brake lights- high brake light & number plate light have all stop working- the fog & indicators work.
Fuse No4 looks good - any ideas before i tkae in to the menders?
thanks
rob
Post #514137 Wed Jan 11 2017 2:07pm
Pufftmw
Bulbs?
Number plate bulb holders get water ingress & blow. I've changed mine to LED now as both were out.
I've just replaced a rear brake light (5v/21v bulb), so they do go too.
What about side lights, you didn't say?
Not sure about high level as that is LED, although 1 of the LEDs has stopped working on mine Rolling Eyes
Post #514144 Wed Jan 11 2017 3:06pm
try changing one of the brake light bulbs on the side.
if that doesn't work, brake pedal switch I guess, they are known to give problems.
number plate lights could be a broken wire at the top of the tailgate I guess.
Post #514160 Wed Jan 11 2017 6:07pm
Throbby
Thanks for your replies. Just odd they all have gone together. May not be relevant but I changed the battery within a couple of days before I was advised they were not working. The battery I upgraded from 17 to 19.
I will check the bulbs the weekend. I remember I had one changed about 5 months ago!
Post #514187 Wed Jan 11 2017 11:00pm
Throbby
Side lights - no nothing only fog & indicators.
Post #514188 Wed Jan 11 2017 11:01pm
