Home > General (L494) > Fuel rail - high pressure fault
Brick
Australia
Evening all,
My SE SDv6 has now done 13,000kms since picking up in mid-Aug. Has been a great performer for me, particularly in the fuel economy stakes. I am averaging 8.8l/100kms using as a daily driver of a minimum 90kms a day.
However, in the last couple of weeks a recurring issue has arisen. I keep getting a fault (high pressure in fuel rail) pop up resulting in reduced performance. I can clear the error with my code reading tool, but the fault keeps coming back.
Have had it back to the dealer twice. First time they tested the fuel rail pressure sensor but could not find a fault (I had cleared before taking to the dealer). The second time I called roadside assist and had it towed with the fault still active. Dealer replaced the sensor and the high pressure fuel pump, but a day later the fault was back. It is going back to the dealer tomorrow morning for its third visit.
Am interested to see if anyone else has had this fault, and if it was able to be resolved. Am wondering if it is a logic issue rather than a mechanical one.
Cheers Cameron
If in doubt, throttle out
MY16 RRS SE SDv6
MY16 Ford Ranger XLT
2008 911 GT2 - my dream came true
1976 Escort mk2 - race car
Post #513053 Wed Dec 28 2016 2:06pm
IRBails
Australia
Wondering if there is a way to test the actual pressure. I know the pressure is extremely high but a test should decide the issue. Swapping out components hoping one is at fault can be a very frustrating way to find a fault. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #513081 Wed Dec 28 2016 10:45pm
Brick
Australia
So after the third visit to the dealer, and sitting in the workshop for 5 weeks this time around, it looks as though the issue has been resolved. A full set of new injectors looks to be the fix. This is after replacing the high pressure fuel pump twice, the low pressure fuel pump, removing the fuel tank and fuel lines to be checked for any damage during the build, replacing the pressure sensor, and checking all electrical connections.
Will wait until they perform some more testing on Monday to confirm the fault does not reoccur, and then I hope to be able to take it home. Cameron
MY16 RRS SE SDv6
Post #516637 Fri Feb 03 2017 2:21pm
wilf
Rarely come across JLR injector issues before (or at least not at this age).
How strange that your car is so afflicted! Still if it fixes the issue I guess. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #516641 Fri Feb 03 2017 3:25pm
IRBails
Australia
Quite strange all injectors are being replaced, perhaps this is because they can't determine which ones are faulty or they think something has contaminated fuel and affected all the injectors. You must be real P!ssed about this, I know what it is like just trying to get parking sensors working on a new car. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #516699 Sat Feb 04 2017 12:03am
Brick
Australia
So I finally picked up the vehicle last night. Have done 100kms and no fault has appeared.
Issue was finally traced to a fault in the Powertrain Control Unit. Was not a software issue as had any updates loaded earlier on in the search for the problem, so believe it was a hardware issue. Maybe a cold solder on a board or something. May find out one day if it gets sent back to the techs. There was only one spare unit in the country, so obviously do not replace this very often. Cameron
MY16 RRS SE SDv6
Post #517882 Wed Feb 15 2017 10:33am
rangiejools
Australia
Good news hopefully you'll be able enjoy your RRS now. RRS P460e
1983 2 door Range Rover ARB Bar X9000 winch ARB Rear Bar now semi retired.
Many big trips done in this one.
1982 Rangerover nearly restored.
22 Defender D250 with lots of stuff for outback touring
Nice 2013 Freelander TD4 manual (for daughter to learn on) with much better stereo compared with previous SD4 SE with Meridian which sounded bad!
2013 Land Rover Defender ute.
Post #517886 Wed Feb 15 2017 11:43am
IRBails
Australia
Well you got a lot of new parts because the dealer or RR Australia didn't know WTF they were doing to start with. Good result for you after the long wait. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #517923 Wed Feb 15 2017 10:36pm
