![]() | Home > General (L494) > Half a heated front screen |
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
I seem to remember something about the L320 having 2 fuses Tim, one for each side of the heated screen? I hope I'm right by saying that but could the RRS2 be the same maybe. |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 ![]() |
I'm not sure if it is 2 fuses but on your vehicle Tim, the heated windscreen is connected by two connectors. My 15MY L405 needed a replacement windscreen and there was only one connection on the new screen. LR changed this circa 16MY so if you're on the original screen, you'll have a dual connector. |
It is a March 2015 build so assume that it is still a 2015MY 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
I have seen connectors in the windscreen pillar burnt out. Easy to get to, for a check. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
My last L320 did this. I believe it was just a fuse. |
The car is in the workshops while the auto-electrician decides if it is the fuses, connections or a new front screen (not really something I want on a 19 month old car) when I checked it in they are also going to apply software upgrade Q634 to something called the "Gateway Module". Wasn't very encouraged by the receptionists remarks that "usually it takes 30 minutes to do the software upgrade......... if it "takes" it the first time!"
Just had a phone call from the dealership bodyshop - new screen was ordered yesterday, arrived this morning, "when can we have the car please?" First class service 24 hours from ordering screen to delivery at the dealership. Their own staff will do the work, they don't farm it out to Autoscreens or whoever. They ask to have the car in overnight, I assume to allow the adhesive to full cure and to carry out a water test.
TheWojtek Member Since: 08 May 2015 Location: PoznaΕ, Poland Posts: 737 ![]() ![]() ![]() |
Check if both sides heat up this time. Regards etc.,
Let's hope the fitters are good Tim as I'm sure they don't change that many screens compared to Autoscreens or whoever so may not be as experienced when it comes to fitting and bonding correctly ![]() 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18β Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning π |
timmos Member Since: 20 Feb 2017 Location: Burton On Trent Posts: 22 ![]() ![]() |
my L320 has the same issue, can any one point me in the direction of what fuses to look at? |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 ![]() ![]() ![]() |
I had same issue. Blown fuse. See here http://www.rrsport.co.uk/forum/topic46957.html Merc C220 estate Sport AMG
Signori Member Since: 30 Jan 2017 Location: Baildon, West Yorkshire Posts: 33 ![]() ![]() ![]() |
Sorry wrong section |
ids Member Since: 08 Sep 2020 Location: Herefordshire Posts: 19 ![]() ![]() |
Know its an old thread but my 2017 RRS has now got this issue on the driver side (RHS)
