Home > General > My first Sport with Steering wandering on poor roads.
Timf
And again...note the rather elderly stable mate!
Post #508282 Fri Oct 21 2016 8:05pm
Eaters
This may be a stupid question, but here goes. Does changing from 40s to 45s have any effect on speedo readings or the like? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #508298 Fri Oct 21 2016 10:04pm
Johnski
Very slightly yes. I believe this can be "adjusted" ?? Sad (or is that me adjusting the MPG figures?) Embarassed John
Post #508302 Fri Oct 21 2016 10:56pm
Eaters
I've just done some maths!!!! Not sure if this is right but I make it that, on the same 20 inch wheels, one revolution of the wheel takes the car an extra 93.4mm (3.6 inches) on the 45 profile when compared to the 40 profile. The circumference of the tyre is 4% more on the 45s than on the 40s.
What this does to the speedo I have no idea Robin
Gone:
MGZTT 190 2.5
Post #508312 Sat Oct 22 2016 7:41am
phillh
If you put larger circumference tyres on, the speedo will show a lower reading for the same speed.
I had this on my old Disco 2 . On standard tyres it read aprox 10% higher (according to the Satnav and a couple of the local speed readouts). When I fitted larger all terrain tyres, it was dead accurate.
Post #508316 Sat Oct 22 2016 8:24am
Jonnytatt
Nice sport that Tim looks great on those 20's and 275s.
Bigger tyres move the speedo yes.
My old Defender had 33" tyres on it and read true to satnav though.
Most cars read less than actual anyway.
Problem 98% cured on my range with a 4 wheel alignment.
2% being i have worn tyres on the front. They are also run flats which give a bad ride . Thanks all for the help.
Post #508350 Sat Oct 22 2016 5:44pm
Jonnytatt
Series 1 Tim in the barn?
Post #508351 Sat Oct 22 2016 5:48pm
Timf
Thanks Jonny, yes a Series 1. I bought her about 15 years ago and have steadily brought her back to original condition. Great fun!
Post #508361 Sat Oct 22 2016 8:07pm
