Home > In Car Electronics > Towing socket
rayc59
United Kingdom 2006 Range Rover Sport TDV6 Bonatti Grey
Towing socket
Hi can anyone tell what the extra lug is for on my range rover sport 2006 it has a additional lug with two wires going into it and this lug connects to the blue as well can you help please and do i need them and where is the best place to buy just the socket
Thanks
Post #507208 Thu Oct 06 2016 5:59pm
The car fog lights can be connected to this
So that the cars fogs are off when trailer plugged in
To stop reflections off white caravans.
Post #507210 Thu Oct 06 2016 6:05pm
rayc59
So i don't really need it then if putting on new plug as i don't tow caravans only a small boat
Thank You
Post #507211 Thu Oct 06 2016 6:47pm
Well anything with a white front. So could apply to a boat.
Anyway if the socket doesn't come with an extra terminal, you will need to connect the single wire to blue No.2 to ensure the car rear fogs work
Post #507255 Fri Oct 07 2016 11:01am
rayc59
Thanks Andy i have been in touch with the company and am just going to exchange socket for the right one
Cheers for info. Thumbs Up Thumbs Up
Post #507277 Fri Oct 07 2016 3:47pm
rayc59
Ok the reason i decided to replace the towing socket was that i had no Right Tail / Side Light I had checked all fuses, checked bulbs plugged in a spare trailer board and got the same as above so i put it down to the socket all other lights work Left Tail /side works, Left and Right indicators work, Brake Stop lights work anyone got any ideas
Post #507359 Sat Oct 08 2016 7:10pm
Check 5a fuses by the jack.
Check there is power on both sides of the fuse when the lights are on.
Post #507360 Sat Oct 08 2016 7:32pm
rayc59
Is this one in the boot Andy
Post #507361 Sat Oct 08 2016 7:37pm
Yes the fuses under the boot floor hatch
Post #507366 Sat Oct 08 2016 8:18pm
rayc59
Thanks Andy will check it in the daylight plus remove all the crap from boot first lol and let you know how i get on
Post #507367 Sat Oct 08 2016 8:41pm
rayc59
Hi Andy been in the boot cant find any fuses under jack
Post #507409 Sun Oct 09 2016 12:48pm
Humm I wonder if you have an aftermarket tow kit,
In which case the fault could be them blue scotch locks.
Normally there are 6 fuses in view when you open the hatch (on early models)
You will just have to follow the towbar wiring to trace the fault.
Probably on the passenger side.
If you want a quick fix;
I guess you could leave the dead wire disconnected and take a feed off the brown or black (which ever one works)
https://goo.gl/images/BnrBJe
See bottom left
Post #507416 Sun Oct 09 2016 2:42pm
rayc59
Yes my boot is exactly the same but no fuses like the picture and the loom is all in one no scotch clips will try to trace it and see whats what Thanks again for all the info
Post #507454 Sun Oct 09 2016 8:30pm
