![]() | Home > In Car Electronics > Towing socket |
rayc59 Member Since: 12 Sep 2015 Location: Scotland Posts: 19 ![]() ![]() ![]() |
Hi can anyone tell what the extra lug is for on my range rover sport 2006 it has a additional lug with two wires going into it and this lug connects to the blue as well can you help please and do i need them and where is the best place to buy just the socket
So i don't really need it then if putting on new plug as i don't tow caravans only a small boat
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Well anything with a white front. So could apply to a boat.
Thanks Andy i have been in touch with the company and am just going to exchange socket for the right one
Ok the reason i decided to replace the towing socket was that i had no Right Tail / Side Light I had checked all fuses, checked bulbs plugged in a spare trailer board and got the same as above so i put it down to the socket all other lights work Left Tail /side works, Left and Right indicators work, Brake Stop lights work anyone got any ideas |
Check 5a fuses by the jack.
Is this one in the boot Andy |
Yes the fuses under the boot floor hatch |
Thanks Andy will check it in the daylight plus remove all the crap from boot first lol and let you know how i get on |
Hi Andy been in the boot cant find any fuses under jack |
Humm I wonder if you have an aftermarket tow kit,
Yes my boot is exactly the same but no fuses like the picture and the loom is all in one no scotch clips will try to trace it and see whats what Thanks again for all the info |
