Home > Maintenance & Modifications > Heated Steering wheel
USAFBuckeye
United States 2007 Range Rover Sport Supercharged Stornoway Grey
Need some help boys,
I have a '12 RRS SC heated steering wheel that I can't get to work. When I depress the button the bottom stays green, which indicates no heat is being produced.
The vehicle is out of warranty, so I'd like to fix this my self if possible. Anyone know how to troubleshoot the heating element and other associated parts?
I know it's a tall order. Thanks in advance! '12 RRS SC
'07 RRS SC
'11 Honda Odyssey Touring Elite (sigh...)
Gone, but not forgotten
'02 RR
'05 LR3 SE7 (Best off-road rig I've ever had) let her go @ 100K miles
Post #505975 Wed Sep 21 2016 4:18am
Firstly I would check fuse No.20 in the foot well fuse box assuming it is the same as a UK spec car.? but as light works it may be ok. Also do a continuity test on the Heating Element and go from there.
Cpl
Post #505982 Wed Sep 21 2016 9:42am
USAFBuckeye
Will do Col.
What am I looking for when doing the continuity check? '12 RRS SC
'07 RRS SC
'02 RR
Post #506011 Wed Sep 21 2016 3:23pm
A low resistance of a few ohms.
Post #506028 Wed Sep 21 2016 9:00pm
USAFBuckeye
Ok. The fuse is good.
If I get low ohms from the element, then is it safe to assume it's the box that generates the signal?
Any other ideas? '12 RRS SC
'07 RRS SC
'02 RR
Post #506157 Fri Sep 23 2016 2:41am
USAFBuckeye
Solved
The main wheel was fine. I had to replace the heater control unit inside that attaches to the back inside of the wheel. Good thing I had the old wheel still.
Thanks for the help! '12 RRS SC
'07 RRS SC
'02 RR
Post #506740 Fri Sep 30 2016 3:52am
