![]() | Home > Maintenance & Modifications > Heated Steering wheel |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Firstly I would check fuse No.20 in the foot well fuse box assuming it is the same as a UK spec car.? but as light works it may be ok. Also do a continuity test on the Heating Element and go from there.
USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60 ![]() ![]() ![]() |
Will do Col.
A low resistance of a few ohms. |
Ok. The fuse is good.
Solved
