![]() | Home > General > RRS battery drain solution found |
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 ![]() ![]() ![]() |
bottled release button?? -----------------------------------------------
Think it's part of the not often heard of optional Bar fittings pack, bottle opener button? ![]() ![]() RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Scouse spec |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
To the OP, well done - it's always nice to find an easy and cheap fix. You should have done some searching on here - the boot switch corrosion issue is fairly well known and documented. |
B11rmo Member Since: 12 Aug 2016 Location: Liverpool Posts: 3 ![]() |
sorry "boot lid release button"
pollawyn Member Since: 07 Dec 2015 Location: cornwall Posts: 19 ![]() ![]() ![]() |
Ok it seems that my boot release button wasn't the only problem!
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Did you find a solution to your battery drain?
Also,
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Heck doesn't anyone read what they've just typed ![]() |
No, not when they now have to drive the Mrs to work, get 2 kids ready for school, and work out how to do s school run plus 2 jobs with 1 car...
Mmm... yes the rest of us aren't busy at all, so have plenty of time to try and decipher your message before we can actually help you. |
Not getting into a silly debate, but unless you can help could you keep the comments off the post?
