Home > General > RRS battery drain solution found |
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 |
bottled release button?? -----------------------------------------------
Fri Aug 12 2016 8:43pm |
Think it's part of the not often heard of optional Bar fittings pack, bottle opener button? John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Fri Aug 12 2016 8:54pm |
Fri Aug 12 2016 10:54pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Scouse spec In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Aug 13 2016 6:58am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
To the OP, well done - it's always nice to find an easy and cheap fix. You should have done some searching on here - the boot switch corrosion issue is fairly well known and documented. 2012 SDV6 - it's missing a couple of cylinders
Sat Aug 13 2016 12:27pm |
B11rmo Member Since: 12 Aug 2016 Location: Liverpool Posts: 3 |
sorry "boot lid release button"
Mon Aug 15 2016 1:10pm |
pollawyn Member Since: 07 Dec 2015 Location: cornwall Posts: 19 |
My battery drain problem turned out to be a faulty door lock. Not only was my RRS continually trying to activate the faulty lock but I had inadvertently been leaving the car unlocked.
Sat Aug 20 2016 8:51pm |
Ok it seems that my boot release button wasn't the only problem!
Mon Aug 22 2016 7:49pm |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
Did you find a solution to your battery drain?
Mon Sep 26 2016 6:08am |
Also,
Mon Sep 26 2016 6:19am |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
Heck doesn't anyone read what they've just typed |
Mon Sep 26 2016 6:41am |
No, not when they now have to drive the Mrs to work, get 2 kids ready for school, and work out how to do s school run plus 2 jobs with 1 car...
Mon Sep 26 2016 7:11am |
Mmm... yes the rest of us aren't busy at all, so have plenty of time to try and decipher your message before we can actually help you. |
Mon Sep 26 2016 7:35am |
Not getting into a silly debate, but unless you can help could you keep the comments off the post?
Mon Sep 26 2016 7:59am |
