![]() | Home > General > Low power when starting to accelerate |
Sounds like egrs failing open. Bodsys Brake Bible
Scotch99 Member Since: 03 Aug 2016 Location: Central Posts: 7 ![]() ![]() ![]() |
Thanks for the reply.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4444 ![]() ![]() ![]() |
They can be blanked. If you can get the car up to Dundee, I can do it for you next week |
Thanks for the offer, what is the cost and how long does it take? The mechanical part I can do easily, is there a software update required? Does my car fall under the earlier 2007?
If you let Disco_Mikey sort it for you, then ask him about a re-map as well, now that will change your car |
Had a spare hour so took out the off side EGR, stripped it down and gave it a clean while it was in bits.
Still not fancy blanking them? |
Just read the thread about blanking egrs when they are still working and it seems to work on some cars, so as i have 2 recently replaced egrs I will try blanking them off at the EGR/manifold end and see if I get any codes.
You will most likely need a software patch to allow blanking on Eu4 models |
Once I have blanked them off I will give you a shout. Thanks |
