Home > General > Low power when starting to accelerate
Scotch99
Scotland 2007 Range Rover Sport TDV6 S Java Black
I have a strange fault
No error message on the dash, when you move off the revs rise to about 1300 and the car moves slowly, the revs slowly rise and at around 2000 rpm the power picks up. This is the same when cruising at a speed and you accelerate, the turbo take 5-10 seconds to spin up.
Is this an actuator fault? An EGR OR A TURBO or inter cooler pipe?
I'm going to read the codes tomorrow.
There's no smoke at any time.
1 in 20 times when starting the engine or as I select park when turning off the car I get "transmission fault" popping up for less than a second.
Thanks
Post #502102 Wed Aug 03 2016 9:17pm
Bodsy
Site Sponsor
Sounds like egrs failing open. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #502104 Wed Aug 03 2016 9:18pm
Scotch99
More info
Thanks for the reply.
Is there a test I can do to bypass the egr before I fork out for new ones? Unplug the leads or remove piping? Or just remove and check if they are sized?
I followed the car home yesterday and once it was moving and the power built up there was black smoke from both tailpipes.
On removing the engine cover I see both egrs, the car is a 8/2007 registered and in the bin checker it says 2008
Can I blank off or not?typical its in the changeover year.
Thanks
Post #502250 Fri Aug 05 2016 4:25pm
Disco_Mikey
They can be blanked. If you can get the car up to Dundee, I can do it for you next week Thumbs Up
Post #502260 Fri Aug 05 2016 7:22pm
Scotch99
Thanks for the offer, what is the cost and how long does it take? The mechanical part I can do easily, is there a software update required? Does my car fall under the earlier 2007?
Thanks
Post #502261 Fri Aug 05 2016 7:28pm
SRE
Spain
If you let Disco_Mikey sort it for you, then ask him about a re-map as well, now that will change your car Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #502297 Sat Aug 06 2016 1:42pm
Scotch99
Update
Had a spare hour so took out the off side EGR, stripped it down and gave it a clean while it was in bits.
They were fairly recent replacement non-OEM parts.
Couldn't see anything obvious except the slots that open and shut the valve as the actuator rotates were a bit rough and groved.
Then when I looked back in the engine bay there was a stainless disc about the size of a £1 coin. It was the actual valve cover that opens and closes. It had come loose from the actuator push rod.
Reattached with a little squeeze to fit tightly. Refitted and all working again.
New part ordered.
Thanks for the pointers.
Post #502346 Sun Aug 07 2016 2:15pm
Disco_Mikey
Still not fancy blanking them?
Post #502347 Sun Aug 07 2016 2:35pm
Scotch99
Yeh, Still plan on blanking
Just read the thread about blanking egrs when they are still working and it seems to work on some cars, so as i have 2 recently replaced egrs I will try blanking them off at the EGR/manifold end and see if I get any codes.
When my EGR stopped working I never got an eml but not yet plugged in my code reader.
Post #502351 Sun Aug 07 2016 3:04pm
Disco_Mikey
You will most likely need a software patch to allow blanking on Eu4 models
Post #502354 Sun Aug 07 2016 5:58pm
Scotch99
Will be in touch
Once I have blanked them off I will give you a shout. Thanks
Post #502357 Sun Aug 07 2016 6:12pm
