![]() | Home > Technical > Tyre Wear Effect on Drive Train |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
Basically, it's a diagnostic service function and can be a solution for driveline slack, judders and the like. The clutch controls the centre diff lock and the control module needs to be calibrated to the precise dimensions to function correctly - sometimes it can go out of calibration and will benefit from a re-jig. Takes a couple of minutes with an appropriate diagnostic tool (IID, Nanocom, SDD etc.). |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
Harshness in the gear train could be the mechatronic unit. If the pressures aren't correct then there will be thunking etc. I believe you can replace solenoid valves in the unit. Problem with the mechatronic unit is that it's a big ticket item. 2012 SDV6 - it's missing a couple of cylinders
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
The gearbox mechatronic unit has been replace under warranty already - it made no difference. |
Hope you are not paying for this haphazardly way to find a fault. Not the way to go, even a LR warranty wouldn't pay up for changing bits to try and rectify faults. John
LR have been paying for trial and error fixes for 4 years - to no avail. |
