Home > Technical > Tyre Wear Effect on Drive Train
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Transfer Box Clutch Calibration
What exactly is a transfer box clutch calibration and how would that affect gearchanges/shunt. I don't believe the dealer has even looked at this. The transfer box was removed from the car and resealed due to an oil leak but nothing more has been mentioned.
Post #503286 Sat Aug 20 2016 2:55pm
Lost for Words
Basically, it's a diagnostic service function and can be a solution for driveline slack, judders and the like. The clutch controls the centre diff lock and the control module needs to be calibrated to the precise dimensions to function correctly - sometimes it can go out of calibration and will benefit from a re-jig. Takes a couple of minutes with an appropriate diagnostic tool (IID, Nanocom, SDD etc.). Thumbs Up Visiting from DISCO3.CO.UK
Post #503299 Sat Aug 20 2016 5:08pm
Harshness in the gear train could be the mechatronic unit. If the pressures aren't correct then there will be thunking etc. I believe you can replace solenoid valves in the unit. Problem with the mechatronic unit is that it's a big ticket item. 2012 SDV6 - it's missing a couple of cylinders
Post #503307 Sat Aug 20 2016 6:30pm
Meiang
Gearbox Mechatronic Unit
The gearbox mechatronic unit has been replace under warranty already - it made no difference.
Post #503330 Sun Aug 21 2016 1:54am
Johnski
Hope you are not paying for this haphazardly way to find a fault. Not the way to go, even a LR warranty wouldn't pay up for changing bits to try and rectify faults. John
Post #503382 Sun Aug 21 2016 8:21pm
Meiang
Trial And Error Fixes
LR have been paying for trial and error fixes for 4 years - to no avail.
Post #503398 Mon Aug 22 2016 5:06am
