Home > Other Site Sponsors > GAP Diagnostic Announcement-2016-07-25-Apple App & More
PatGapInnov
Canada
Hello Everyone
First, we would like to thank all our customers, beta testers and the community for your continuous support. Many new additions were the results of your feedback and suggestions. We could not be where we are without you!
As many of you already know by now, a new App, version 2.9, for Apple devices was released over the week end. We’ve also released a new special firmware available for beta testers only at the current time. I will do a second post shortly showing each point in detail but here’s a resume of the new additions when using both the new App and firmware or using the new App only with an older firmware.
Top Bar (new and old firmwares): A new bar was added which shows the current connection and ignition status as well as battery voltage.
Faults function (new and old firmwares): Advanced Read
-Status bit flags default selection can be saved for future use
-Status bit flags are visible as icons on top of fault descriptors
-Status bits can be included in the exported emails
Height Adjust (new firmware only): A new and more intuitive screen to adjust your suspension height with default and saved settings. Contrary to our previous method, height changes are relative to the default height and not the current standard height.
0 -> 25: current height, 0 mm, or default in this example is shown on the left while the selected height setting (My offroad height in this example) is shown right, + 25 mm
20 -> -10: current height, +20 mm relative to the normal height (0 mm), shown on the left while the selected height setting (Motorway in this example) is shown right, -10 mm relative to the normal height (0 mm).
Height Control (new firmware only): This function allows you to remotely control your current height (Access, Normal, Offroad) and lower both axles to the bumpstops.
Suspension Calibration (new firmware only):
-New manual calibration layout
-New guided calibration function. This unique method eliminates the need for calculations, even ground and requires only one iteration. The whole process takes 5 minutes.
Guided calibration instructions:
• The first corner to be calibrated is the front left corner (1).
• Place your measuring tape as instructed and use the up and down arrows (2) to reach the required height (3).
• Once completed, click on Send (4). The next corner to be calibrated will now be high-lighted.
• Repeat the previous steps for all corners.
New Suspension Test Valve function layout (new firmware only)
Live values:
-All live values (PIDs) are now available for all supported vehicles (L322: except for older BMW type ECUs, new firmware only)
-Trigger function which allows custom audible or vibration alarm and automatic start/stop logging of live values. (new and old firmwares)
Trigger example:
• The live value increases and passes the Start target of 20 % (first red dotted line)
• Recording begins and the previous data is kept (2 seconds, as set)
• The Stop condition is met at around 6.5 seconds, hence the trigger indicator (red dotted lines)
• Recording continues for 4 seconds as set
• Enabling the Buzzer will generate a sound when the condition is met. Perfect when moni-toring live data. Can be used without using the automatic recordings feature.
-Favourite Fast Add feature which allows adding live values to favorite list quicker. (new and old
firmwares)
• Click on the star when viewing an ECU live values
1- Click here to create a new list
2- Current favourite lists are shown here
3- Click on the star to add the live value to this favourite list
-Layout improvements (new and old firmwares)
-Selection of which live values to be exported and viewed (logs). (new and old firmwares)
Car Configuration File (new and old firmwares):
-Complete CCF list can be edited upon request.
-Favourite Fast Add feature which allows adding configurations to favorite lists quicker.
ECU Info (new firmware only): This new layout is the basis for what will be the next step reflashing wise. It now shows which ECUs are up to date and those for which a newer version is available. If you are testing this function, please send us the results using the send e-mail button for our records. This will help us validate the automatic file selection algorithm.
An historic of each ECU Info scan is saved and can be recalled.
Tool Activation (new and old firmwares): Initial activation of the IIDTool can all be done within the App when the mobile device is connected to the internet. Additional licences can also be entered in the App.
New French version (except for live values and car config, new firmware only)
Documentation: The user manual was completely overhauled and will be released in the comming days in French and English.
Jaguar support: It is now possible, upon request, to use the IIDTool BT or Pro on 2008 and up Jaguars.
Work on the Android App is still under way. If you are using Android devices only, please do not update to the special firmware 2434 (English), 2435 (French) or 3630 (Pro English), 3631 (Pro French) and up since the firmware is not backward compatible with earlier App versions. You can, however, revert back to the latest beta if Android usage is required after using it on an Apple device.
Our current beta testers using Apple devices can benefit from these new additions by updating the App to V2.9 and IIDTool firmware to:
BT:
-Special Build 2439 (English, French upon request)
Pro:
-Special Build 3643 (English, French upon request)
We strongly recommend updating your mobile device operating system (iOS) to the latest version prior to using the new App and firmware.
As usual, feedback is more than welcome! For those who are not currently beta testers and want to test the new App and firmware simply send us an e-mail or a PM.
Cheers Thumbs Up
Edit: Added pictures and additional comments. http://www.gap-diagnostic.com/
Post #501630 Mon Jul 25 2016 5:44pm
Buckster
This is awesome, can't wait to have a play with the new layout and features when I return home, many thanks Pat and keep up the excellent work Bow down Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #501648 Mon Jul 25 2016 8:49pm
aljo
Excellent work as usual Thumbs Up
Post #501650 Mon Jul 25 2016 9:01pm
fkarim
I tried it today. The top bar is very useful, especially the battery voltage. Previously I had to go into Live Values and select it in one of the ECUs just to check battery voltage. Having it displayed at the top all the time is very handy Thumbs Up
Looking forward to official release of the latest firmware. Hopefully I can enable some freebies in the CCF then Wink Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Post #501651 Mon Jul 25 2016 9:01pm
Johnski
Will be updating my IID BT tomorrow, now I've seen this. The newer version for suspension seems a vast improvement. Thumbs Up John
Post #501668 Tue Jul 26 2016 12:24am
PatGapInnov
Canada
Edited first post, picture and more details.
fkarim: send me a PM if you want complete CCF access... http://www.gap-diagnostic.com/
Post #501830 Thu Jul 28 2016 8:45pm
luckske
Belgium 2010 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
Amazing! Only recently bought an IID tool and it's such an amazing device!
Updated the app a few days back and it looks great, the top bar is a big improvement. Read through the new manual today and the new features look great, looking forward to the final release! Thumbs Up
Thanks for your continuous support!
Post #501833 Thu Jul 28 2016 9:26pm
Wilson
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
received my IIDtool BT today, firmware update and activation were all very simple with excellent guides! my god there were so many faults stored that had never been cleared That bit is all simple enough but the height adjust is a little overwhelming for me, I think I messed it up but set back to default thankfully.
Would love a dummy's guide to changing settings, I basically want the access and normally values very slightly lower 10mm ish without changing the off road value!
Are there any other little quirky adjustments I can make to the car using the tool such as putting the clock in the dash and anything else useful?
Post #534124 Wed Aug 30 2017 7:21pm
PatGapInnov
Canada
Hello Wilson
A Land Rover without any faults code is not a Land Rover Wink
One can only adjust the standard height which is the reference point for all other height modes. You can, however, have different preset values which can be quickly called. For example, setting 1 can be -10 mm and setting 2 -20 mm. A few clicks will change the current point to either default, setting 1 or 2. The user manual is your friend, page 85, else, please ask!
https://www.gap-diagnostic.com/support/documents/IIDTool/
The clock on dash feature is also described in the document, reflash section, page 156. If you have a 2006 which I assume you have since you do not have the clock on dash, have a look at the BCM Body Control (3 turn flash), Bluetooth and Suspension flash which are also interesting.
As far as Car Configuration File settings, have a look and change them at will.
Cheers! http://www.gap-diagnostic.com/
Post #534125 Wed Aug 30 2017 7:34pm
Wilson
I had looked at page 85 briefly but the missus was starting to nag that I'd spent a lot of time on the RRS tonight so I didn't really take it all in... Rolling Eyes
Oh all sounds exciting, I will be having a read of all those extras tomorrow, thanks for the suggestions Thumbs Up
Regards
Wilson
Post #534126 Wed Aug 30 2017 7:46pm
Wilson
I'm a bit worried about this 'flashing ecus' I don't like the bit that states Risk Level, followed by unusable Sad Not sure I've got the balls to have a go... I'll tackle most things that require a spanner, but ecus and electrics scare the hell out of me.
I'd prefer a dummies guide.. do this then that etc.. Embarassed Confused
Post #534127 Wed Aug 30 2017 7:57pm
PatGapInnov
Canada
Start with the low risk ones to get the feel of things. The BCM is the riskiest and prevention is key. Follow the suggestions and you will be just fine. http://www.gap-diagnostic.com/
Post #534129 Wed Aug 30 2017 8:03pm
Wilson
Thank you Very Happy
I'll give a shout if I have any doubts, but a good read through first should be enough Thumbs Up
Post #534134 Wed Aug 30 2017 8:20pm
PatGapInnov
Canada
Sounds good Thumbs Up http://www.gap-diagnostic.com/
Post #534174 Thu Aug 31 2017 12:15pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Is it possible to update the maps on a 2010 rrs with this device?
Thanks
Post #534211 Thu Aug 31 2017 7:25pm
