![]() | Home > General (L494) > Both fobs not working !!! |
lrdaft Member Since: 29 Mar 2009 Location: scotland Posts: 43 ![]() ![]() ![]() |
My sport is 9 months old and tonight I had to manually unlock the door and place the fob next to the steering coloum to start it , tried spare key . Exactly the same , any ideas? Or is it trip to dealer no 3? |
Batteries are critical, must be new and sealed replacement, no moisture by touching battery either.
Batteries are fine . Both fobs not working , used genuine Panasonic batteries , I think it must be the keyless module
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 ![]() ![]() |
Both keys should be with the car when it goes in for service, part of the service is to check they both work and to update if not 100% |
Maidenmania Member Since: 13 Feb 2014 Location: Yorkshire Posts: 138 ![]() ![]() |
This happened to mine , breakdown man pulled a fuse out in the boot and it worked again. The part that recognises the keys was then replaced under warranty 2008 Factory HST- Sold
Thanks , I take it it's been fine since?
It was fine when he unplugged the fuse out but it went in for another problem and I mentioned it and they changed it not sure which fuse or module though sorry 2008 Factory HST- Sold
Must be another "known fault" |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Silly, that is a "characteristic". |
New "kvm" module fitted
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
Old post but had same problem 2 week ago. Pulled keyless locking fuses out x 2, put back in and all ok. Been ok ever since (it has only been 2 week......) |
