Home > General > The dredded judder
mac01642
United Kingdom 2007 Range Rover Sport TDV6 HSE Fuji White
The dredded judder
Hi guys
Recently had a wynns gearbox flush, solved all running issues and the car drove like a dream
Now 6000 miles later , the revs are fluctuating and vibrating/ juddering at 40mp and 60mph
Now what ? Let me guess torque converter ? Has anyone had the same? What is a cost approx of changing the TQ supplied and fitted
Post #499928 Thu Jun 30 2016 4:50pm
MJ87
United Kingdom 2011 Range Rover Sport SDV6 HSE Fuji White
I had a similar issue a few thousand miles after having mine flushed. There wasn't any previous issues with the gearbox, I did it as preventative maintenance but it was around 109k. It ended up with a re conditioned gearbox and torque converter from Martin Lowe transmissions at Barnsley..... There car park and workshop was rammed with jaguar and land rovers Neutral
I'll pm you the price if you want.
Good luck
Post #499938 Thu Jun 30 2016 7:38pm
mac01642
I hope it not that serious
Yes please send the price
Post #499953 Thu Jun 30 2016 9:32pm
MJ87
Pm sent.
What's your mileage?
Post #499956 Thu Jun 30 2016 10:18pm
SH0X
Wow this sounds horrible
all from a preventative measure aswell. The saying ' ain't broke don't fix it' comes right to mind there but how horrible is it when you were trying to do the right thing by the car or any future owners to get it flushed !
This judder... could you reset the gearbox adaptation ?I saw on the diagnostic tool an option for that... but not fully sure what it does in detail
Post #499964 Fri Jul 01 2016 2:17am
Lost for Words
It won't have been caused by the flush itself. The damage will have been done beforehand, and the flush may or may not have caused it to show itself now, but ultimately the damage was done before (unless, of course, there was something wrong with the flush).
It may be that only a TC is required (typically £1-1.5k) but it could be a full recon (£2k upwards). What mileage are we talking? Is the box still shifting smoothly? Fault codes may be stored if the box has issues.
Do not reset the gearbox adaptations at this point - it can do more harm than good. Thumbs Up Visiting from DISCO3.CO.UK
Post #499980 Fri Jul 01 2016 8:24am
Bodsy
Site Sponsor
I would drain the transmission oil, then add two tubes of Dr Tranny, and top the oil up. Cost about £60 and is likely to at least delay the inevitable torque converter change. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #499982 Fri Jul 01 2016 8:53am
mac01642
MJ87 wrote:
Pm sent.
Thank you and my mileage is 107k
Post #500018 Fri Jul 01 2016 5:49pm
mac01642
Already done this, this was part of my flush price
Post #500019 Fri Jul 01 2016 5:50pm
MJ87
Just to be clear, I accept that the flush didn't cause my gearbox failure. I'd still recommend a gearbox flush to people but urge them to do it sooner rather than later. Thumbs Up
Good luck with yours Mac.
Post #500028 Fri Jul 01 2016 11:05pm
