![]() | Home > Faults & Fixes > Engine fault loss of power black smoke |
I'm guessing it's tdv6, if you fill your profile in, it helps us to help you. |
f11rfn Member Since: 25 Apr 2014 Location: england Posts: 21 ![]() |
sorry its 2.7 tdv6 2005 plate.. could it be electrical as its temperamental? like o2 sensor? |
Could be many things. Best get the fault codes as a starter as it could be over fuelling or a MAF sensor. Narrow the location down a bit in your profile and someone may be nearby who can scan the cars codes. Bodsys Brake Bible
im in birmingham il have to get a code check done hopefully solve it |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Split inter cooler pipe 61 AB 5.0 supercharged rocket
