Home > Faults & Fixes > Engine fault loss of power black smoke
f11rfn
hi guys my car has been throwing up engine system fault up and it goes into limp mode with loss of power, when i switch it on and off it was going back to normal. Other day after fueling it up the warning message came up and loss of power with black smoke, i tried the on and off thing but still was the same. i read on here it indicates boost leak, but after leaving it parked for few hours its back to normal with no issues Confused ... so bit puzzled as if was boost leak it would not go? ive driven it on motorway and local for few days and its been fine? any help would be appreciated.. ps the egr valves have been already been blanked off.
Post #499197 Wed Jun 22 2016 10:52am
Bodsy
Site Sponsor
I'm guessing it's tdv6, if you fill your profile in, it helps us to help you. Thumbs Up
Usual culprit is a split in the intercooler boost pipe going to the air intake. Or split in intercooler, or turbo issues. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #499203 Wed Jun 22 2016 11:27am
f11rfn
sorry its 2.7 tdv6 2005 plate.. could it be electrical as its temperamental? like o2 sensor?
Post #499206 Wed Jun 22 2016 11:40am
Bodsy
Site Sponsor
Could be many things. Best get the fault codes as a starter as it could be over fuelling or a MAF sensor. Narrow the location down a bit in your profile and someone may be nearby who can scan the cars codes. Bodsys Brake Bible
See it HERE
Post #499207 Wed Jun 22 2016 11:45am
f11rfn
im in birmingham il have to get a code check done hopefully solve it
Post #499209 Wed Jun 22 2016 11:47am
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Split inter cooler pipe 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #499352 Thu Jun 23 2016 8:53pm
