![]() | Home > Maintenance & Modifications > Waxoyl undersealant |
Check out the various offerings from Bilt Hamber, I think the range is Dynax, have heard some very good reviews though not used these products specifically.
FloydRRS Member Since: 16 Jun 2016 Location: Wiltshire Posts: 9 ![]() ![]() |
Thanks Beancounter_74 I will have a look at that |
Dinitrol
Cheers Dr Rob I will have a look at that as well |
Not used him personally but he's a Dinitrol approved place close to you
Ok so had a good look at both, I was initially going to do it myself so swayed to the Bilt Hamber Dynax for ease of use out of the can but I am liking the look of JWC and the Dinitrol and thinking it will save me time and hassle!
I'd drop by and have a chat with them and then make a decision.....
taffboyo74 Member Since: 17 May 2016 Location: pembrokeshire Posts: 10 ![]() ![]() ![]() |
spend a bit money and get it done properly. took mine to a place called rust master, spent ages washing off the chassis, then dries off with a heater then ages coating it. you will not have a proper job doing it yourself plus you will get covered in the stuff |
