Home > Maintenance & Modifications > Powerflush |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4943 |
includes everything. |
Wed Jun 15 2016 10:26am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
That's not a power flush, that's a standard Land Rover filter and fluid. A power/mega flush would be £250ish. The standard filter and fluid change doesn't change all of the oil - it changes about half of it because much of the oil is held in the torque converter and doesn't drain when you take the pan off. 2012 SDV6 - it's missing a couple of cylinders
Fri Jun 17 2016 5:26pm |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 |
Yes it's being powerflushed. And having new filter and pan fitted at the same time. |
Fri Jun 17 2016 6:09pm |
That'll use a bit of oil then. You'll lose half of it when you drop the pan then presumably it needs to be filled to level before the powerflush because the oil needs to be at a certain temperature which requires the gearbox to be run. So you're using 1.5 times the normal amount of oil. Is this at a LR dealership? If so, check they are actually going to do a dialysis flush rather than what they call a flush - which is as I described earlier just a flush of the box. 2012 SDV6 - it's missing a couple of cylinders
Fri Jun 17 2016 6:44pm |
Not at land-rover dealership.
Fri Jun 17 2016 8:01pm |
Car running nice and smooth. Should be at just over £500 for megaflush 9 litres of oil and new pan and filter. |
Sat Jun 25 2016 2:19pm |
