Home > Faults & Fixes > Tdv8 2009 rrs turbo issues
Mani
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Thanks Paddi once again,
all sorted now it was the actuator roads, both replaced with new upgraded Stainless Steel ones.
problem cured and fuel economy seems to also improved Very Happy Very Happy Thumbs Up Thumbs Up
Post #501891 Sat Jul 30 2016 10:52am
ragpicker
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Sumatra Black
Did you notice a repetitive squeak from the engine after you'd switched it off for about 10-15 seconds - sounds a bit like a boy-scout's bunk bed?
Mine does this, wondering if its the actuators cleaning and squeaking because they are about to seize...
Might try getting in there somehow to lube them...
Post #501892 Sat Jul 30 2016 1:04pm
The squeaking after shut down is the EGRs cycling to ensure they don't jam up. 2012 SDV6 - it's missing a couple of cylinders
Post #501894 Sat Jul 30 2016 2:04pm
Disco_Mikey
The turbos also cycle on start up and shut down Thumbs Up
Post #501900 Sat Jul 30 2016 4:40pm
ragpicker
Turbo's or EGR's, should they squeak? If its a sign of something, what can I do about it?
Cheers Question
Post #501903 Sat Jul 30 2016 4:49pm
Paddi
At least if the turbo actuator rods are squeaking you know something is moving! The rods can be lubricated from below if you remove the plastic shielding but its a long reach up to them. Search the forum and you'll find various ingenious methods including straightened out coathanger with tubing zip tied it used as a means of extending the reach of teflon spray.
If my EGRs are typical then you'll hear a high pitched buzz on key off that goes on for a surprisingly long time. 2008 MY Java Black TDV8 HSE
Post #501956 Mon Aug 01 2016 11:40am
ragpicker
Had my suspension re-callibrated today by a local indy (Oakfields - stockton). Whilst in there I mentioned it to the chap and he said that there are several things which cycle when the ignition is switched off - the egr's, the turbo actuators, the throttle bodies, the air flaps and something else apparently??
Anyway, first class service from this indy today - squeezed me in as an emergency and did the calibration for free Thumbs Up
Post #501978 Mon Aug 01 2016 7:46pm
