Home > Faults & Fixes > Tdv8 2009 rrs turbo issues |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
Thanks Paddi once again,
Sat Jul 30 2016 9:52am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The squeaking after shut down is the EGRs cycling to ensure they don't jam up. 2012 SDV6 - it's missing a couple of cylinders
Sat Jul 30 2016 1:04pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
The turbos also cycle on start up and shut down |
Sat Jul 30 2016 3:40pm |
ragpicker Member Since: 21 Mar 2016 Location: Teesside Posts: 47 |
Turbo's or EGR's, should they squeak? If its a sign of something, what can I do about it?
Sat Jul 30 2016 3:49pm |
At least if the turbo actuator rods are squeaking you know something is moving! The rods can be lubricated from below if you remove the plastic shielding but its a long reach up to them. Search the forum and you'll find various ingenious methods including straightened out coathanger with tubing zip tied it used as a means of extending the reach of teflon spray.
Mon Aug 01 2016 10:40am |
Had my suspension re-callibrated today by a local indy (Oakfields - stockton). Whilst in there I mentioned it to the chap and he said that there are several things which cycle when the ignition is switched off - the egr's, the turbo actuators, the throttle bodies, the air flaps and something else apparently??
Mon Aug 01 2016 6:46pm |
