Home > General > Two holes either side on front inner wheel arch?! |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
They might be for the optional tyre pressure monitors. I'm in the shed, I'll be back in the real world in a minute. |
Fri Jun 03 2016 1:50pm |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 |
It would help if you noted down your RRS Type and model year!
Fri Jun 03 2016 2:00pm |
sean2204 Member Since: 05 Mar 2016 Location: York Posts: 55 |
Ha good point.
Fri Jun 03 2016 2:08pm |
Fri Jun 03 2016 2:42pm |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Mudflaps. Regards etc.,
Fri Jun 03 2016 2:49pm |
^ +1 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jun 03 2016 3:16pm |
Thank you very much. So nothing missing per se then. |
Fri Jun 03 2016 4:12pm |
scousefly Member Since: 24 Jan 2015 Location: sheffield Posts: 248 |
Yes there are usually slide on protectors one for each side. Range Rover Sport Front Wheel Arch Seal. They only slide on so not fixed in place. One was missing on mine when I bought so I replaced with new ones about £30 off Ebay. Part Number: CLB500061 |
Fri Jun 03 2016 6:40pm |
Thanks mate. I'll get some order asap. |
Fri Jun 03 2016 6:55pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
They are £15.89 inc VAT each genuine new LR genuine part.
Fri Jun 03 2016 7:46pm |
are they the rears? I looked on eBay and the fronts were identified as 51 at the end instead of 61... |
Fri Jun 03 2016 7:53pm |
They are pre drilled for mudflaps - the wheel arch protectors are situated higher on the arch 16MY Estoril Blue SVR.............
Fri Jun 03 2016 8:14pm |
Cheers... so do I need anything or is it just standard to be open to the elements like that?
Fri Jun 03 2016 8:47pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4973 |
These are a good buy, exactly the same as a Sport and enough to do the whole vehicle twice as they fall off the Sport every couple of years. http://www.ebay.co.uk/itm/Land-Rover-Freel...XQYwFRiRqZ Cheers Col |
Fri Jun 03 2016 8:50pm |
