![]() | Home > General > Two holes either side on front inner wheel arch?! |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
They might be for the optional tyre pressure monitors. I'm in the shed, I'll be back in the real world in a minute. |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
It would help if you noted down your RRS Type and model year!
sean2204 Member Since: 05 Mar 2016 Location: York Posts: 55 ![]() ![]() |
Ha good point.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Mudflaps. Regards etc.,
^ +1 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thank you very much. So nothing missing per se then. |
scousefly Member Since: 24 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
Yes there are usually slide on protectors one for each side. Range Rover Sport Front Wheel Arch Seal. They only slide on so not fixed in place. One was missing on mine when I bought so I replaced with new ones about £30 off Ebay. Part Number: CLB500061 |
Thanks mate. I'll get some order asap. |
They are £15.89 inc VAT each genuine new LR genuine part.
are they the rears? I looked on eBay and the fronts were identified as 51 at the end instead of 61... |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
They are pre drilled for mudflaps - the wheel arch protectors are situated higher on the arch |
Cheers... so do I need anything or is it just standard to be open to the elements like that?
These are a good buy, exactly the same as a Sport and enough to do the whole vehicle twice as they fall off the Sport every couple of years. http://www.ebay.co.uk/itm/Land-Rover-Freel...XQYwFRiRqZ Cheers Col |
