Home > In Car Electronics > DRL Activation
Dan Stevens
Australia 2006 Range Rover Sport TDV6 SE Zermatt Silver
DRL Activation
Sorry guys i know this isn't RRS related but i have a mate with a Disco 4.
How do you activate the DRL LED's to come as DRL's and not with the main lighting?
Any help appreciated
Post #496379 Wed May 18 2016 12:31am
If it is anything like RRS 1 UK Spec. cars you can't.
Posted this previously.
Have gone into the CCF files and there are three options listed on my car a MY13 A/B 5.0L S/C.
1. DRL Standard
2. Scandinavian
3. Canadian
I activated Standard and all that did was give me two Fault Codes B124A-15 and B124B-15 which are Left and Right Daytime Running Light open Circuit but no working DRL's so it may be when you have either DRL lamp kit VPLSV0064 or 65 fitted you may have to activate this but that is purely a guess. By the way those kit's are over £400.00
De-activated that and then activated Canadian and what that did was nothing with ignition on and Engine Running, however when you engage Drive and let the Park Brake Off it Switched Front and Rear Side Lights and Dipped Headlights On, as soon as you apply P/B and take it out of Drive It switches them Back Off.
Again De-activated that and Activated Scandinavian and what that did was as soon as you Start Engine it Switched on Front and Rear Sidelights and Dipped Headlights. (Muddy was correct there).
There is no facility that I could find to just activate the Front Fairy Lights on there own as DRL's.
Post #496383 Wed May 18 2016 4:28am
