Home > General > Buyers guide what to look out for. |
No need to be scared of buying if you go in with your eyes wide open, remember that anything that looks too good to be true usually is.............. And don't be swayed by body kitted, jazzed up, chipped, modified cars. RRS is a complex car and repair prices are often high, there are lots out there and many have been abused so do plenty of research.
Mon May 02 2016 8:54am |
Ste77 Member Since: 01 May 2016 Location: Newcastle upon Tyne Posts: 31 |
Ive been trying to find out various things etc.. dont suppose you know which type of gearbox would be in an 06 model or is that something id find out on the logbook? |
Mon May 02 2016 5:26pm |
All pre 2010MY RRS have a 6 speed Auto, there is no such thing as a manual Sport! All have a low ratio transfer box too so ALWAYS change that the transfer system between high and low boxes is working smoothly and almost silently. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon May 02 2016 8:32pm |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Have a look at the buyers guide on the following link from forum member 'Paddi'.
Tue May 03 2016 7:42pm |
Equium Duo Member Since: 01 May 2016 Location: Reykjavik Posts: 2 |
Can you fix the link? It seems to have been shortened and now doesn't work! |
Tue May 03 2016 11:15pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The gearbox in a 2006 is a ZF 6HP26 6-speed automatic. It almost certainly will not have had anything done to it unless it broke in some way earlier in its life. LR state that the gearbox oil is good for 150k miles. This is rubbish. If the gearbox on the one you are looking at shifts smoothly and behaves as one would expect, then budget £250+ for a gearbox oil change as soon as you get it home. This is for a "mega flush" oil change, not the LR method and is more effective.
Wed May 04 2016 8:15am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Have cambelts been changed should of been done at 7 years or 105000 miles which ever sooner obviously age in this case.. Good luck.. 2008 G4 RRSport TDV8 current
Wed May 04 2016 9:16am |
http://www.rrsport.co.uk/gallery/albums/us...uide~0.pdf
Wed May 04 2016 9:58am |
Thanks for that RRSTDV8 |
Wed May 04 2016 11:09am |
The Garage is doing the belts if they havn'nt been done.. i still need to get a look at all paperwork for it after testdrive tonight |
Wed May 04 2016 11:12am |
It's worth looking at the wiki on disco3.co.uk. The RRS shares many of its issues with the Disco 3 as they are basically identical below the body. 2012 SDV6 - it's missing a couple of cylinders
Wed May 04 2016 12:38pm |
Thanks Paddi. Don't know what happened to the link I tried to post. I'm in the shed, I'll be back in the real world in a minute. |
Fri May 06 2016 1:11pm |
Thanks for all the info guys the search continues |
Sat May 07 2016 5:00pm |
What happened on the test drive that put you off? I'm in the shed, I'll be back in the real world in a minute. |
Mon May 09 2016 2:06pm |
