Home > Faults & Fixes > Starter motor fault |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 |
As long as 4 days? Nice one glad you got it sorted though. Just FYI as you're in the Oxfordshire area, as am I, James French in Standlake seems to be a LR specialist people speak highly of. |
Tue Apr 26 2016 8:54pm |
Mmarques Member Since: 09 Apr 2016 Location: Oxfordshire Posts: 76 |
Haha yep not even a week, must be a record!
Tue Apr 26 2016 9:48pm |
It'll be James French you're looking for. Standlake garage is probably the other one down the road. Mine was back in the workshop twice within a week fine now though thankfully. |
Tue Apr 26 2016 9:58pm |
Surely if you've only had it a week you would get the seller to replace it with a new one !? |
Wed Apr 27 2016 9:02am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
It would help if you filled in your profile, model, year, engine etc 2008 G4 RRSport TDV8 current
Wed Apr 27 2016 12:20pm |
I have sent them an email this morning, awaiting a reply, the car hasnt got any warranty on it. I did update my profile with vehicle details but not sure why its not updating |
Wed Apr 27 2016 1:37pm |
Hi camelrock, I did fill in my vehicle details in my profile but for some reason its not updating? Vehicle is a rrs 2006 4.4 v8 petrol |
Wed Apr 27 2016 1:38pm |
Unless you bought it privately you've got a warranty.
Wed Apr 27 2016 2:34pm |
Thank you socast, I did not know this, I only thought the car would only have warranty if it was added when bought.
Wed Apr 27 2016 2:42pm |
The garage I bought mine from took the car in twice in the first 7 days and sorted everything out free of charge. Courtesy car free of charge as well. Good job you didn't buy private You get a warranty as standard but you can buy extra ones with better cover over a longer term. |
Wed Apr 27 2016 4:39pm |
Thats good that they sorted everything out for you FOC.
Wed Apr 27 2016 6:08pm |
Up to you really. I first took mine back as I couldn't lower into access mode. I tested it as working on the test drive, but they replaced the front ARB bushes before I picked it up. One of the height sensors was knocked, I think, which caused the access level fault. The replaced that, gave it a full 4x4 recalibration, all good.
Wed Apr 27 2016 6:12pm |
Apart from the starter fault that came up, the other faults arent big, more annoying than anything like the passenger wing mirror has a fault (ive posted a thread about it but no answer yet) it doesnt adjust on the drivers mirror control but it tilts when in reverse dip mode, better explained in the thread, there is a Cv boot which has a small cut in it which I noticed when looking at the car on the forcourt and they said to just get it booked in with them and they'll sort it out foc which was good of them.
Wed Apr 27 2016 6:22pm |
CV boot is an MOT fail, if they gave you a 12 month ticket when you bought the car then they obviously cant lay straight in bed. That needs doing sooner rather than later as a dry cv joint can make a mess at worst and cause premature wear at best.
Thu May 05 2016 11:40am |
