Home > Technical > 'Variable Effort Steering' - HEAVY STEERING!
ezzycozzy
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
I have just bought a 2013 RRS. On test driving it I just thought it was fairly heavy steering due to the large tyres, but I've had it scanned for a fault at my local garage & its coming up 'Variable Effort Steering'....the guy in the garage is clueless about it, before I take it into the dealership, (££££££!!!) does anyone know anything about this and how much it is likely to fix it? Steering is really heavy & also steering column control switch isn't working either! Thanks
Post #494373 Sun Apr 24 2016 8:25pm
shakeapaw
could be the lower steering ball joint, mine went really heavy, and it is a known fault, the knuckle siezes up, its around £100 plus fitting for a new one 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #494375 Mon Apr 25 2016 3:47am
The steering is speed sensitive so the error could be related to that. The steering control is part of the air suspension control module which is located on the A pillar behind the steering wheel. Would be worth checking that there are no loose connections to the module. It's easy enough to access.
Most likely is that the PAS pump is on its way out... 2012 SDV6 - it's missing a couple of cylinders
Post #494382 Mon Apr 25 2016 9:56am
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Private sale or garage, if its the latter they should sort it for you as its a safety issue Thumbs Up
Post #494384 Mon Apr 25 2016 9:59am
ezzycozzy
Private sale from a business associate! (says the steering was always heavy due to the tyres)
Post #494409 Mon Apr 25 2016 3:15pm
shakeapaw
You need to put some air in them then Smile 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #494721 Fri Apr 29 2016 7:15am
ezzycozzy
Had a guy look at it & was some kind of software issue. had that and the steering wheel column switch fixed for £200. The difference is unreal!!
Post #494988 Mon May 02 2016 7:04pm
Good result. It's nice when they're working properly! Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #495032 Tue May 03 2016 8:54am
