![]() | Home > Tips & Tricks > road angel classic and RRS please help!! |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
I have the Road Angel Plus and it works fine in the middle of the RRS windscreen!
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 ![]() ![]() |
mate you had any trouble with your road angel plus.. mine is dead.. battery issues.. and paulL's is dying too.. Gecko's was on when i drove his S4 to the last meet, but noticed his was plugged in too..
Havank Member Since: 20 Jun 2006 Location: West Sussex - UK Posts: 691 ![]() |
I also had lots of problems with the sat-nav in the van, has something to do with the sun-reflective windscreen, so needed an external antenna and all works fine
The night before last weeks meet i went to update my RA on the PC. I did have the software on it so downloaded that to get the lasted update. But first it did a new firmware update half way the screen went red and i thought it was dead!! so just left it the way it was and called RA them self. Tec support rang me back very quick (hour or so) He told me what to do and the end it was all normal! Think this may help with a few problems it has! RRS TDV6 Gone but still around
welsh alex Member Since: 15 Oct 2006 Location: england Posts: 17 ![]() ![]() ![]() |
thanks jaymann and havank,
Yes it's wired all i did was pop the trim off and push it back on but it may not be as easy as that in the RRS!
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
Common problem with heated screens, the heater elements in the glass can block or reduce any signals coming through it (satellite signals etc), only solution would be an external antenna or place it where it can get sufficient signals through the side glass. Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
simonsi,
Update - mine struggles a bit on the dash but worked fine on the centre console on the cupholders! ![]() Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
I have a Road Angel and it needs the Road Angel internal antenna which you fit to the the bottom right side of the screen where there's no heated screen element. No power required, plugs straight into the back of the unit and permanently sticks to the inside of screen, costs about £10, takes 5 mins to fit. Will not work, or not work as well, without it. Had same exactly problem with Mercedes SL and Freelander. When you change cars, take it with you. Good Luck! |
you dont have a road angel classic then? as these cant have that ariel and must have re-radiating with power from cig. lighter. im currently doing without ![]() |
Mine's a Road Angel Classic (ie the older one, black with green lcd screen) and seems fine, I guess we don't quite understand what combinations work/don't or else something isn't consistent across units/cars???? Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Apologies! Mine is indeed a New Road Angel, but I can fully appreciate your frustration as I can remember when I first encountered the problem and just couldn't figure out the reason. Good Luck! |
