Home > Tips & Tricks > road angel classic and RRS please help!!
welsh alex
hi all
we got out 2007 rrs tdv6 hse one week ago and really enjoying it. but please, please , please can you tell me how to get my road angel classic working on the dashboard
ive tried putting it nearer the corner at the bottom right but it doesnt find satellites, must i get an external ariel ?? as soon as i put it out of the window the satellites show up (3-5 of them)
also those of you who get it working in the corner how do you mount it on the dash? any pics about? putting the road angel in the corner of the dash seems to cause it to be at a poor angle etc
basically - love the car - missing the road angel !!
many many thanks
alex
Post #67221 Mon Nov 20 2006 11:28pm
I have the Road Angel Plus and it works fine in the middle of the RRS windscreen!
But not in the van nor my TomTom works in there i got a external ariel for the TomTom and it wo*k grate in it now Very Happy
Try this i may get one for the Van!
http://cgi.ebay.co.uk/GPS-Antenna-Aerial-M...dZViewItem RRS TDV6 Gone but still around
Post #67222 Mon Nov 20 2006 11:39pm
kam100
mate you had any trouble with your road angel plus.. mine is dead.. battery issues.. and paulL's is dying too.. Gecko's was on when i drove his S4 to the last meet, but noticed his was plugged in too..
The guys i bought mine off, have not given me any problems and told me to send it back in a box just the unit and they'll send me a new one, but not sure i want another one.. may send the whole thing back and tell them to send me a normal road angel a wire one, and give me some money back.. i know its road angels first product with a rechargeable battery but i have seen/heard of thousands going wrong, so somewhere down the line someone has messed up big time getting these tested and out onto the market! i used to rave about them before, and still agree that when they work they are mint, and really do help.. but if they aren't working and you get flashed.. i will be well annoyed!!
Post #67228 Mon Nov 20 2006 11:58pm
Havank
I also had lots of problems with the sat-nav in the van, has something to do with the sun-reflective windscreen, so needed an external antenna and all works fine
so could be the same problem with the windscreen in the RRS, so just get an external antenna
Post #67248 Tue Nov 21 2006 10:49am
The night before last weeks meet i went to update my RA on the PC. I did have the software on it so downloaded that to get the lasted update. But first it did a new firmware update half way the screen went red and i thought it was dead!! so just left it the way it was and called RA them self. Tec support rang me back very quick (hour or so) He told me what to do and the end it was all normal! Think this may help with a few problems it has! RRS TDV6 Gone but still around
Post #67249 Tue Nov 21 2006 10:54am
welsh alex
thanks jaymann and havank,
i asked that company on e bay and they said the original road angel (classic) is not supported! their list also confirms it
also for external antennae how do you run it out of the car?? is it wired??
cheers
Post #67285 Tue Nov 21 2006 1:54pm
Yes it's wired all i did was pop the trim off and push it back on but it may not be as easy as that in the RRS!
And to get it on to the roof i just ran it on the in side of the door there's just the right gap for it but this was in the van and not the RRS RRS TDV6 Gone but still around
Post #67286 Tue Nov 21 2006 2:08pm
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
Re: road angel classic and RRS please help!!
welsh alex wrote:
...it doesnt find satellites
Common problem with heated screens, the heater elements in the glass can block or reduce any signals coming through it (satellite signals etc), only solution would be an external antenna or place it where it can get sufficient signals through the side glass. Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #70351 Tue Dec 12 2006 3:41pm
welsh alex
simonsi,
yes im hoping it will work through rear side glass , bought re-radiaiting antennae but feedback stopping it working in the front of car.
Post #71194 Sat Dec 16 2006 6:34pm
simonsi
welsh alex wrote:
simonsi,
Update - mine struggles a bit on the dash but worked fine on the centre console on the cupholders! Confused Cheers
Simon
Post #71221 Sun Dec 17 2006 12:23pm
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
I have a Road Angel and it needs the Road Angel internal antenna which you fit to the the bottom right side of the screen where there's no heated screen element. No power required, plugs straight into the back of the unit and permanently sticks to the inside of screen, costs about £10, takes 5 mins to fit. Will not work, or not work as well, without it. Had same exactly problem with Mercedes SL and Freelander. When you change cars, take it with you. Good Luck! Wink
Post #75737 Tue Jan 16 2007 7:24pm
welsh alex
you dont have a road angel classic then?
as these cant have that ariel and must have re-radiating with power from cig. lighter. im currently doing without Mad
Post #75759 Tue Jan 16 2007 9:08pm
simonsi
Mine's a Road Angel Classic (ie the older one, black with green lcd screen) and seems fine, I guess we don't quite understand what combinations work/don't or else something isn't consistent across units/cars???? Cheers
Simon
Post #75771 Tue Jan 16 2007 10:36pm
Brian Mason
Apologies! Mine is indeed a New Road Angel, but I can fully appreciate your frustration as I can remember when I first encountered the problem and just couldn't figure out the reason. Good Luck!
Post #77413 Tue Jan 23 2007 8:39pm
