Home > Technical > Can I tow a twin axle caravan on a DETACHABLE towbar? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
You can tow a big tin tent, many people do. Just as with any towing, you need to keep an eye on the tow bar and makes sure you look after it. Take it out when not being used, keep it and the receiver clean etc. If you're worried, buy a LR tow ball and then get your dealer to carry out the receall check on it. At least then you'll have an idea as to the state of your receiver to begin with. To be honest, if it's been lightly used in the past then it's probably ok. For towing two or three times a year, the removable ball is fine - that's what it's intended to do. 2012 SDV6 - it's missing a couple of cylinders
Sat Mar 19 2016 5:54pm |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 |
yes is the Answer 2007 SUPERCHARGED HST |
Sat Mar 19 2016 9:59pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
No problem towing twin axle with detachable. I used the same towbar for 6 years on 2 RRS with no issue
Sat Mar 19 2016 10:17pm |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677 |
The answer is yes,I used to tow mine without any problems before I sold it.
Sun Mar 20 2016 6:25am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Consider buying a brand new one though and not one on eBay that was left permanently on a vehicle / used for heavy towing which led to wear in the receiver.
Sun Mar 20 2016 9:18am |
If you buy second hand and see dealer on recall they'll replace it if worn provided you're smart Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Sun Mar 20 2016 9:49am |
midsman Member Since: 24 Dec 2013 Location: West Midlands Posts: 63 |
Would confirm yes. We tow a Swift Elegance 645 behind our RRS. No problems with the detachable lowball. Just take it out when not being used. Use the red plastic plug for the RRS latching point to stop dirt etc going in when not in use. Make sure that you clean the towing head with brake cleaner on a regular basis to save contamination of the friction pads on the caravan. Our detachable tow bar was checked and lubricated by the dealer at the last service. 2015 Range Rover Sport Autobiography Dynamic SDV6
Sun Mar 20 2016 12:00pm |
