Home > Faults & Fixes > Parking Brake
Philgibbs
United Kingdom 2008 Range Rover Sport TDV6 S Stornoway Grey
Parking Brake
Hi,
I think my module is knackered , I have reset it twice, and every time it works ok once or twice then james again,
the brakes shoes are fine, My part No is LR01223, about £450, but i have found one part No 072318 on ebay for £250, it looks the same in every way, Does anyone think it will fit ?
2008 sport 2.7
thanks Phil
Post #490884 Mon Mar 14 2016 2:11pm
Socast
Before replacing the module, try adjusting the shoes.
If it's jamming it might be worth stripping the drums and cleaning it all off too.
Post #490891 Mon Mar 14 2016 2:58pm
Philgibbs
We had stripped and cleaned brakes, first then reset it, it worked once ok, then went again. Someone has said they need to be plugged in to reset module ?
Post #490904 Mon Mar 14 2016 5:22pm
Philgibbs
Post #490906 Mon Mar 14 2016 5:29pm
Blackedition
United Kingdom 2010 Range Rover Sport TDV6 Autobiography Java Black
I have a similar issue but my parking brake comes on and off ok...just when I'm pulling off it creaks slightly & seems like it's slightly seized on the rear passenger side...but then seems ok until the next time it's applied ...
I've had the rear calliper replaced...new pads...brake shoes cleaned adjusted...
Noise is only from the passenger side rear
Any ideas people? Thanks in advanced
Post #496476 Wed May 18 2016 10:36pm
