Home > Faults & Fixes > Remove door latch |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Hi You need to remove the window motor unit. Also you will need to secure the glass in the closed position. I used masking tape to hold it in position. Unclip the window, Undo all the bolts and it slides out once tilted. Once removed you will be able put your hand in to remove the latch. Takes about 45mins from removing door card to replacing. |
Thu Feb 25 2016 12:24am |
Whelan Member Since: 24 Feb 2016 Location: Laois Posts: 2 |
Thanks for response. Will try again later.
Thu Feb 25 2016 7:47am |
