Home > Technical > key fob 2012my
tonyninety
United Kingdom 2012 Range Rover Sport SDV6 SE Buckingham Blue
key fob 2012my
on replacing the battery it was inserted the wrong way up and now does not work even though the batt is now correctly installed.Is it now u/s or can it be made to work correctly.
Post #487073 Wed Feb 10 2016 12:39pm
URX
Scotland
I think i still have a new uncoded one i bought from fleabay if you get stuck
I had intended just to swap the intrnals over if the outside shell got damaged but miraculously both keys survived intact till trade in dec.
Its common for electronics to have a little diode to prevent reverse polarity connections but if they blow not sure hoe you fix it.. RRS1 2009 - 2012
RRS1.5 2012 - 2016
RRS2 ...you are kidding right?
Post #487098 Wed Feb 10 2016 6:00pm
