![]() | Home > Technical > EPB Position "Undefined" |
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 ![]() ![]() |
I have had the dreaded EPB screech and hand brake jam and had to use the manual release as the IIDTool unjam did not work.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4455 ![]() ![]() ![]() |
The module/cables need to be latched to determine its position |
It certainly looks like they are re-latched, I can see where the white plastic connector on the offside has moved away from the edge of the EPB module casing and I believe this indicates that it has relatched.
Just checking though, how do I push the cables back together exactly? |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
grab the two halves of the slider and squeeze them together you should feel a click.
So just to make sure ("borrowed" Disco_Mikeys image |
Yes
