Home > Technical > EPB Position "Undefined" |
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 |
I have had the dreaded EPB screech and hand brake jam and had to use the manual release as the IIDTool unjam did not work.
Fri Feb 05 2016 6:47am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
The module/cables need to be latched to determine its position
Fri Feb 05 2016 7:41am |
It certainly looks like they are re-latched, I can see where the white plastic connector on the offside has moved away from the edge of the EPB module casing and I believe this indicates that it has relatched.
Fri Feb 05 2016 7:47am |
Just checking though, how do I push the cables back together exactly? |
Fri Feb 05 2016 8:20am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
grab the two halves of the slider and squeeze them together you should feel a click.
Fri Feb 05 2016 10:14am |
So just to make sure ("borrowed" Disco_Mikeys image ), push at the 2 arrows and ensure the latch (circled) clicks into place.
Sat Feb 06 2016 12:56am |
Yes
Sat Feb 06 2016 9:33am |
