Home > Technical > Footbrake sound linked to "PARK" transmission
Page 1 of 3 123>
Tonight when leaving work I put my foot on the brake and there was a strange sound & clunk sensation? It was linked to the gear selector, when in P ...... if I took my foot off the brake and reaplied it.... It would do the same sound each time. It sounded like a relay operating??? you could also feel this noise if you know what I mean ???
has anyone experienced this before?
I will monitor - but none the less will be screaching my way back to the dealer = For gods sake ...... it's just been bloody serviced Twisted Evil
Post #66327 Tue Nov 14 2006 9:46pm
Bobby
Yes, I've felt it.
I think its the 'release' mechanism working, meaning when the footbrake is applied the gear lever is 'released' so that you can shift to R or D.
Just put your hand on the gear selector lever and keep on applying the footbrake intermittently - one can feel the sensation. Should not be anything to worry about, I believe. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #66370 Tue Nov 14 2006 10:50pm
But after 12 months of total silence,,,,,,,,,,,,,, and now CLICK,,,,,,,, each time I touch thr foot brake Mad it's not right ..... dealers tomorrow it is then.
Post #66382 Wed Nov 15 2006 12:38am
GefRRspts350
Australia 2011 Range Rover Sport 3.0 TDV6 HSE Alaska White
Re: Footbrake sound linked to "PARK" transmission
[quote="MDP"]Tonight when leaving work I put my foot on the brake and there was a strange sound & clunk sensation? It was linked to the gear selector, when in P ...... if I took my foot off the brake and reaplied it.... It would do the same sound each time. It sounded like a relay operating??? you could also feel this noise if you know what I mean ???
has anyone experienced this before?quote]
Sometimes at the traffic lights, I feel a minor 'clud' while my foot is on brake pedal. I believe it is the gear box deciding to engage first or second gear? Could it be this you are feeling? It seems very minor to me.
Cheers - hope it helps.
Geoff Smile 2011 RRS HSE TDV6 (Alaska/Ebony & Piano Black - Premium/Tow/Rear Lock Diff/Premium ICE/20" Stormers
2006 RRS SE TDV6 (Chawton/Ebony) - GONE!!
Geoff Smile
Post #66386 Wed Nov 15 2006 2:16am
Bobby
Well, if its that loud perhaps you should check it out.
It should actually be more of a 'feel' than a sound. Malaysia Boleh!
Post #66388 Wed Nov 15 2006 4:11am
Q8_LR3
Kuwait
My D3 acts the same on P and N position, I think that it's a safety feature. 05' LR3, V8 HSE, Adriatic Blue
Post #66390 Wed Nov 15 2006 6:26am
IT's definately a loud "CLICK" ........... I would say its a relay that is not fuctioning correctly!
From no sound at all to click click click click each time I touch the brake = NO !
Banging Head
Post #66400 Wed Nov 15 2006 9:24am
Cliff H
I have noticed a slight click sometimes, but if it is a repeated click it sounds like another trip to the dealer Rolling Eyes
Post #66402 Wed Nov 15 2006 9:33am
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Does is click too when you get above a few miles per hour? Sounds like the relay.
That said, I think there must be two relays in the selector; one which stops taking it out of park unless the brake is on, and one which stops D/N - but this is disabled when travelling as you can, of course, select drive and neutral when in motion.
Post #66403 Wed Nov 15 2006 9:37am
Ive felt this as well but thought it was just the relay switching the brake lights on Confused RRS TDV6 Gone but still around
Post #66404 Wed Nov 15 2006 9:40am
Only when stationary Confused
Post #66406 Wed Nov 15 2006 10:38am
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
Completely normal sound...what happens is that usually you have subconsciously already squeezed the shift knob to put it into R or D while pressing the brake pedal, so you don't notice the clicking sound.
Same thing happened to me after about 1 month of ownership...had it validated with the dealership...totally normal. PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #66438 Wed Nov 15 2006 3:18pm
After visit to dealer in my lunch hour [ or 2 ] they confirmed that the noise is coming from a Solenoid that operates the "park lock "
A new/replacement solenoid has been ordered for fitting next week = Result. Thumbs Up
Post #66445 Wed Nov 15 2006 4:18pm
PJPR01
Hhmmm...so under normal circumstances, you don't have any click at all with the vehicle in Park, and then pushing and releasing the brake pedal?
Odd...I have felt this on my RRS and all of the LR3 loaner cars...wonder if there is some other sound then. PJPR
Cairns Blue HSE
Post #66454 Wed Nov 15 2006 5:22pm
That's correct - never used to hear a thing ....... was always silent. But this happened over night.... its a right old clunky click and you can also feel it through/via the gear selector if you hold it at the same time as you press on the footbrake.
Sit in car - shut door - start car - In " P " hold gear stick & press brake = clunk-click .......... sit there and continually tap on the brake pedal..... it will clunk-click each and every time you press the brake...... without moving the gear selector.....
Post #66457 Wed Nov 15 2006 5:31pm
Page 1 of 3 123>
