![]() | Home > Technical > oil pump failure , what additional damage may be caused ? |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
Welcome. |
davidsherry33l Member Since: 12 Dec 2015 Location: hartlepool Posts: 23 ![]() ![]() ![]() |
Hi,
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Failed oil pump = scrap engine. |
well the garage I bought it from is attempting to repair it .... and as i said im going to extend the warranty anyway , I suppose time will tell. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4455 ![]() ![]() ![]() |
Read your warranty documents VERY carefully, and find out the max claim limit
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Yeah - if oil pump failed and bearing )shells) were damaged , there is likely to be a lot of other damage too. You need to find a similar mileage engine from a wreck or a professionally rebuilt engine. |
I appreciate all your comments guys , but me demandning a new / reconditioned engine and actually getting one are 2 different things.
also , the wear on the shells could this not be down to general wear ? and totally coincidental ? as soon as the warning lights flashed up i pulled over and was only doing 10mph .... |
Jaguar Land Rover neither sell parts to repair the bottom end of a TDV6, nor have JLR released repair instructions for the same engine. So how an LR technician can decide if it is repairable is questionable. In addition (with it being a PSA unit) both Peugeot and Citroen also do not sell parts to repair the engine I think that tells you all you need to know about a "recon" engine I presume the body is off the car, engine removed and stripped down? |
Hi,
In all honesty, id have lost the plot after 5 weeks, and told them to shove the car
Oil pump failure is about as serious as it gets. You would be very lucky to be able to rebuild the engine even if the bits were available.
I think the reason they have had it so long is that they have had a lot of other work on at the moment and as they have gave me a car to use ...fixing my car has not been a priority.
Once the car has been repaired what do you expect any independent 'expert' to see; a visual "lift the hood' might show a nice clean engine so what?
