Home > General (L494) > Electronic oil check malfunction |
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 |
While driving over Xmas (HSE, Dec 2013, amazingly 38k trouble-free miles) a warning came up that the electronic oil level check was not working. Since then the warning has not returned BUT the oil level is showing at MAX – which I know is wrong because after its second service in October it was showing in the middle and no more oil has been added.
Mon Jan 11 2016 4:42pm |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
Does it read the same when checked both cold and hot (after turning off for 15 mins) |
Mon Jan 11 2016 7:01pm |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 |
And, of course, is it madness to make an engine without a dipstick?[/quote]
Mon Jan 11 2016 7:07pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
^^^ This is important. The oil level can read higher than the past without adding more oil depending on how long the engine has been off for (and of course whether parked on a slope) when the readings were taken. When I got oil level and temperature sensor fault on my RRS1 it wasn't temporary and stayed there until fixed. Oil level couldn't be checked (showed as 'unavailable' in the conditions where it should have been available) during that time. If your sensors are faulty, replacing them may be quite an involved job because it is the same engine as my previous car and sensor could be equally inaccessible. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Mon Jan 11 2016 9:45pm |
gdaniels Member Since: 09 Sep 2013 Location: Guatemala Posts: 5 |
I have few miles on my Sport, but am unable to check the oil level. Everytime I try,I get an "unavailable " message. I have never had the patience to sit there for ten minutes after I shut down, but get the same results when the engine is cold. Guess i had better check with my Dealer |
Wed Jan 20 2016 11:08pm |
URX Member Since: 09 Feb 2009 Location: Edinburgh Posts: 194 |
mine failed under warranty..but before finally cr4pping out it showed max all the time..
Thu Jan 21 2016 9:46am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
URX - what were the symptoms of it failing? Visitor from fullfatrr.com
Sun Mar 12 2017 3:25pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 533 |
Hi, You don't have to wait 10 mins. To read the oil level. "Cold" do the following:- Pop the bonnet ( no need to actually open it) Switch on the power ( don't touch the brake pedal) Do the "oil level check" routine. When it comes up "unavailable", press "cruise resume" twice (I think) - on l494 you don't need to do this. The oil level should indicate but allow for the lack of expansion I.e. It will read slightly low. Finally - open & shut the bonnet. Can't say who told me about this - but you don't think LR Dealers wait 10 mins at every service do you? Scrumps. Somerset - Where the apples do grow and the cider do flow! 2021 Defender 90 D250 HSE in Tasman with white roof. 24MY D300 AB - Verasine Blue - 😀 19MY SDV6 AB - Byron Blue - Gone 17MY D5 SDV6 HSE - Firenze Red - Gone 16MY SDV6 AB -Aruba Silver - Gone 13.5MY SDV6 "HSE Black" - Baltic Blue - Gone 10MY TDV8 HSE Galway Green - Gone 14MY D4 HSE in Scotia Grey - Gone 05 TD5 D90 CSW in Cairns Blue |
Sun Mar 12 2017 6:28pm |
